7. Device- and Class- Specific Functions Manager¶
7.1. Introduction¶
The device- and class- specific functions manager is …
The directives provided by the device- and class- specific functions manager are:
- cfgetispeed - Reads terminal input baud rate
- cfgetospeed - Reads terminal output baud rate
- cfsetispeed - Sets terminal input baud rate
- cfsetospeed - Set terminal output baud rate
- tcgetattr - Gets terminal attributes
- tcsetattr - Set terminal attributes
- tcsendbreak - Sends a break to a terminal
- tcdrain - Waits for all output to be transmitted to the terminal
- tcflush - Discards terminal data
- tcflow - Suspends/restarts terminal output
- tcgetpgrp - Gets foreground process group ID
- tcsetpgrp - Sets foreground process group ID
7.2. Background¶
There is currently no text in this section.
7.3. Operations¶
7.4. Directives¶
This section details the device- and class- specific functions manager’s directives. A subsection is dedicated to each of this manager’s directives and describes the calling sequence, related constants, usage, and status codes.
7.4.1. cfgetispeed - Reads terminal input baud rate¶
CALLING SEQUENCE:
#include <termios.h>
int cfgetispeed(
const struct termios *p
STATUS CODES:
The cfgetispeed() function returns a code for baud rate.
DESCRIPTION:
The cfsetispeed() function stores a code for the terminal speed stored in a
struct termios. The codes are defined in <termios.h> by the macros BO,
B50, B75, B110, B134, B150, B200, B300, B600,
B1200, B1800, B2400, B4800, B9600, B19200, and
B38400.
The cfsetispeed() function does not do anything to the hardware. It merely
stores a value for use by tcsetattr().
NOTES:
Baud rates are defined by symbols, such as B110, B1200, B2400. The
actual number returned for any given speed may change from system to system.
7.4.2. cfgetospeed - Reads terminal output baud rate¶
CALLING SEQUENCE:
int cfgetospeed(
STATUS CODES:
The cfgetospeed() function returns the termios code for the baud rate.
DESCRIPTION:
The cfgetospeed() function returns a code for the terminal speed stored in
a struct termios. The codes are defined in <termios.h> by the macros
BO, B50, B75, B110, B134, B150, B200, B300,
B600, B1200, B1800, B2400, B4800, B9600, B19200,
and B38400.
The cfgetospeed() function does not do anything to the hardware. It merely
returns the value stored by a previous call to tcgetattr().
NOTES:
7.4.3. cfsetispeed - Sets terminal input baud rate¶
CALLING SEQUENCE:
int cfsetispeed(
struct termios *p,
speed_t speed
STATUS CODES:
The cfsetispeed() function returns a zero when successful and returns -1
when an error occurs.
DESCRIPTION:
B38400.
NOTES:
This function merely stores a value in the termios structure. It does not
change the terminal speed until a tcsetattr() is done. It does not detect
impossible terminal speeds.
7.4.4. cfsetospeed - Sets terminal output baud rate¶
CALLING SEQUENCE:
int cfsetospeed(
struct termios *p,
speed_t speed
STATUS CODES:
The cfsetospeed() function returns a zero when successful and
returns -1 when an error occurs.
DESCRIPTION:
The cfsetospeed() function stores a code for the terminal speed stored in a
struct termios. The codes are defiined in <termios.h> by the macros
and B38400.
The cfsetospeed() function does not do anything to the hardware. It merely
NOTES:
7.4.5. tcgetattr - Gets terminal attributes¶
CALLING SEQUENCE:
#include <unistd.h>
int tcgetattr(
int fildes,
struct termios *p
STATUS CODES:
EBADF |
Invalid file descriptor |
ENOOTY |
Terminal control function attempted for a file that is not a terminal. |
DESCRIPTION:
The tcgetattr() gets the parameters associated with the terminal referred
to by fildes and stores them into the termios() structure pointed to by
termios_p.
NOTES:
NONE
7.4.6. tcsetattr - Set terminal attributes¶
CALLING SEQUENCE:
#include <unistd.h>
int tcsetattr(
int fildes,
int options,
const struct termios *tp
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
7.4.7. tcsendbreak - Sends a break to a terminal¶
CALLING SEQUENCE:
int tcsendbreak(
int fd
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
This routine is not currently supported by RTEMS but could be in a future version.
7.4.8. tcdrain - Waits for all output to be transmitted to the terminal.¶
CALLING SEQUENCE:
#include <unistd.h>
int tcdrain(
int fildes
STATUS CODES:
EBADF |
EINTR |
Function was interrupted by a signal |
ENOTTY |
DESCRIPTION:
The tcdrain() function waits until all output written to fildes has been
transmitted.
NOTES:
NONE
7.4.9. tcflush - Discards terminal data¶
CALLING SEQUENCE:
int tcflush(
int fd
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
7.4.10. tcflow - Suspends/restarts terminal output.¶
CALLING SEQUENCE:
int tcflow(
int fd
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
7.4.11. tcgetpgrp - Gets foreground process group ID¶
CALLING SEQUENCE:
int tcgetpgrp(
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
7.4.12. tcsetpgrp - Sets foreground process group ID¶
CALLING SEQUENCE:
int tcsetpgrp(
STATUS CODES:
E |
The |
DESCRIPTION:
NOTES:
