D-Link DFE500-Tx 21140-A with DP83840 transceiver.
Kingston EtherX KNE100TX 21140AE.
Netgear FX310 TX 10/100 21140AE.
SMC EtherPower10/100 With DEC21140 and 68836 SYM transceiver.
SMC EtherPower10/100 With DEC21140-AC and DP83840 MII transceiver.
Note: The EtherPower II uses the EPIC chip, which requires a different driver.
Surecom EP-320X DEC 21140.
Thomas Conrad TC5048.
Znyx ZX345 21140-A, usually with the DP83840 N-Way MII transciever. Some ZX345
cards made in 1996 have an ICS 1890 transciver instead.
ZNYX ZX348 Two 21140-A chips using ICS 1890 transcievers and either a 21052
or 21152 bridge. Early versions used National 83840 transcievers, but later
versions are depopulated ZX346 boards.
ZNYX ZX351 21140 chip with a Broadcom 100BaseT4 transciever.
Our DEC driver has not been tested with all these cards, only with the D-Link
DFE500-TX.
[DEC21140 Hardware Manual] DIGITAL, DIGITAL Semiconductor 21140A PCI Fast Ethernet LAN Controller - Hardware Reference Manual.
[99.TA.0021.M.ER]Emmanuel Raguet, RTEMS Cache Management For Intel.
