rtems_status_code rtems_object_set_name( rtems_id id, const char *name );
RTEMS_SUCCESSFUL
- name looked up successfully
RTEMS_INVALID_ADDRESS
- invalid name pointer
RTEMS_INVALID_ID
- invalid object id
This service sets the name of id
to that specified
by the string located at name
This directive is strictly local and does not impact task scheduling.
If the object specified by id
is of a class that
has a string name, this method will free the existing
name to the RTEMS Workspace and allocate enough memory
from the RTEMS Workspace to make a copy of the string
located at name
is of a class that
has a thirty-two bit integer style name, then the first
four characters in *name
will be used to construct
the name.
