Every RTEMS object which has an Id may also have a name associated with it. Depending on the API, names may be either thirty-two bit integers as in the Classic API or strings as in the POSIX API.
Some objects have Ids but do not have a defined way to associate
a name with them. For example, POSIX threads have
Ids but per POSIX do not have names. In RTEMS, objects
not defined to have thirty-two bit names may have string
names assigned to them via the rtems_object_set_name
service. The original impetus in providing this service
was so the normally anonymous POSIX threads could have
a user defined name in CPU Usage Reports.
