rtems_status_code rtems_semaphore_obtain( rtems_id id, rtems_option option_set, rtems_interval timeout );
RTEMS_SUCCESSFUL
- semaphore obtained successfully
RTEMS_UNSATISFIED
- semaphore not available
RTEMS_TIMEOUT
- timed out waiting for semaphore
RTEMS_OBJECT_WAS_DELETED
- semaphore deleted while waiting
RTEMS_INVALID_ID
- invalid semaphore id
This directive acquires the semaphore specified by
id. The RTEMS_WAIT
and RTEMS_NO_WAIT
components of the options parameter
indicate whether the calling task wants to wait for the
semaphore to become available or return immediately if the
semaphore is not currently available. With either RTEMS_WAIT
or
RTEMS_NO_WAIT
, if the current semaphore count is positive, then it is
decremented by one and the semaphore is successfully acquired by
returning immediately with a successful return code.
If the calling task chooses to return immediately and the current
semaphore count is zero or negative, then a status code is returned
indicating that the semaphore is not available. If the calling task
chooses to wait for a semaphore and the current semaphore count is zero or
negative, then it is decremented by one and the calling task is placed on
the semaphore's wait queue and blocked. If the semaphore was created with
the RTEMS_PRIORITY
attribute, then the calling task is
inserted into the queue according to its priority. However, if the
semaphore was created with the RTEMS_FIFO
attribute, then
the calling task is placed at the rear of the wait queue. If the binary
semaphore was created with the RTEMS_INHERIT_PRIORITY
attribute, then the priority of the task currently holding the binary
semaphore is guaranteed to be greater than or equal to that of the
blocking task. If the binary semaphore was created with the
RTEMS_PRIORITY_CEILING
attribute, a task successfully
obtains the semaphore, and the priority of that task is greater than the
ceiling priority for this semaphore, then the priority of the task
obtaining the semaphore is elevated to that of the ceiling.
The timeout parameter specifies the maximum interval the calling task is
willing to be blocked waiting for the semaphore. If it is set to
RTEMS_NO_TIMEOUT
, then the calling task will wait forever.
If the semaphore is available or the RTEMS_NO_WAIT
option
component is set, then timeout is ignored.
The following semaphore acquisition option constants are defined by RTEMS:
RTEMS_WAIT
- task will wait for semaphore (default)
RTEMS_NO_WAIT
- task should not wait
Attempting to obtain a global semaphore which does not reside on the local
node will generate a request to the remote node to access the semaphore.
If the semaphore is not available and RTEMS_NO_WAIT
was
not specified, then the task must be blocked until the semaphore is
released. A proxy is allocated on the remote node to represent the task
until the semaphore is released.
A clock tick is required to support the timeout functionality of this directive.
