BSP and Device Driver Development Guide
This corresponds to the driver read call. After validating the minor
number and arguments, this call enables reads from the specified
memory area by invoking the user supplied "enable reads handler"
and then reads the indicated memory area. When
invoked the argument_block
is actually a pointer to the following
structure type:
typedef struct { uint32_t offset; void *buffer; uint32_t length; uint32_t status; } Non_volatile_memory_Driver_arguments;
The driver reads length
bytes starting at offset
into
the partition and places them at buffer
. The result is returned
in status
After the read operation is complete, the user supplied "disable reads handler" is invoked to protect the memory area again.
