procedure Object_Id_Get_Node( ID : in RTEMS.ID; Node : out RTEMS.Unsigned32 );
Returns the node portion of the object Id.
This directive returns the node portion of the provided object id
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the id
provided.
