NOT SUPPORTED FROM Ada BINDING
RTEMS.SUCCESSFUL
- period initiated successfully
RTEMS.INVALID_ID
- invalid rate monotonic period id
RTEMS.INVALID_ADDRESS
- invalid address of statistics
This directive returns statistics information associated with the rate monotonic period id in the following data record:
This directive returns the current statistics information for
the period instance assocaited with id
. The information
returned is indicated by the structure above.
This directive will not cause the running task to be preempted.
