procedure Clock_Get_TOD ( Time_Buffer : in RTEMS.Time_Of_Day; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL
- current time obtained successfully
RTEMS.NOT_DEFINED
- system date and time is not set
RTEMS.INVALID_ADDRESS
- time_buffer
is NULL
This directive obtains the system date and time. If the date and time
has not been set with a previous call to
rtems.clock_set
, then the
RTEMS.NOT_DEFINED
status code is returned.
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems.clock_set
is required to re-initialize the
system date and time to application specific specifications.
